bug in corona material converter A7.1
I use corona material converter A7.1 for convert vray material. Sometime, function “show maps in VP(slow)” it not work. After I use it all maps in scene it not show. Please help me, thank you.
It doesn’t work for everything, it’s just a nasty workaround. The function just tries to activate “show map in viewport” for everything in a diffuse slot. This only works for bitmaps or other simple map types - so it is possible that it won’t work for any more “complicated” setups.
How to show all map it viewport or solution of this problem? Thank you.
