BUG: infinite hole at the center bottom of the space.
Dear Enscape community
We had this issue with our Enscape for quite some time. When we run the enscape, there is infinite hole at the bottom of the space.
It happens to both revit and sketchup environment, to any computers we are running in our firm.
We reached out to the tech, and based on the instruction, we upgraded both our video card and enscape to the latest, re-installed enscape couple times. However, it seems this issue was unsolvable.
Would anyone at Forum encounter the same issue and know how to solve it?
Many thanks,
Andrew from Atelier SUN
Did you try some external HDRIs instead of the standard Enscape ones?
Yea, that looks like the bottom row of pixels from the image you’re using as an hdri is being stretched in towards the centre … NOT down… in.
Unless you are planning to float your building in mid-air and have no ground whatsoever then the ground you build will obscure the lower part of your background
Hey @ateliersun
As Mattias and Paul already pointed out, this ‘ground plate’ is standard in our horizons as this is where your project would be to cover this.
You can get many free high quality HDRi’s from websites like Polyhaven or HDRmaps.
