Bug: Objects disappear from IR when moved.
This is a new and weird one. I’m using latest daily (6th Dec 2021), Max 2021.2, Windows 10.
The video screen capture should be self explanatory - I move an object and it disappears from the IR. I’m not sure if it’s always happening (probably not, but I can’t not make it happen unless I do a max restart).
Not shown in the video: An ‘undo’ makes it reappear, and restarting the IR makes all the objects come back. Also, it’s not happening to all objects. I tested moving a car proxy and it didn’t disappear… very odd.
The only third-party culprit I can think of that might be to blame here is FP.
Tough I do suspect this is a Corona issue. I’m using the CoronaSlicerMaterial in this scene (for the first time in a real-project scene), so maybe that has something to do with it?
Good luck and thanks for any tips!
This does indeed seem like a bug, would you be able to send the scene over to us?
Cheers,
Rowan
Hi, sure thing. Uploaded to Dropbox: “AAOUVIZ_IR BUG SCENE.zip” (still uploading for next 37 mins)
Thanks, I have the scene and I can reproduce the issue. I’ll let you know when I have some more info.
Cheers,
Rowan
(Report ID=CRMAX-1187)
Hi, I know no daily has been released since reporting this, I’m just checking in to see if you’ve been able to fix this yet?
I just noticed it started happening again, seemingly without cause after about a month where the bug didn’t occur.
Very strange as it’s the same scene I’ve been working on for 2 months now and all of a sudden today, the same bug is happening.
afaik it was fixed internally already
Excellent news. Thanks
Keep an eye on the daily builds thread :wink:
As promised, fixed in the latest daily build. You can grab it here: https://forum.corona-renderer.com/ Corona Renderer 8 for 3ds Max - Daily Builds Changelog #msg193862
Let me know if you have any more issues.
Rowan
