When I exclude some of the objects from a light, it behaves normal with GI-off.
The excluded objects render black as you can see in the attachment.
But when I enable GI, the indirect lighting from this light illuminates the excluded objects too.
Is this a bug or an expected behavior?
If it is expected behavior how can I create the effect I want (indirect lighting of the specific light affecting only the included objects) ?
Thanks for reply but this doesn’t solve my problem because there are more than one light in the scene.
If I make this, then it will exclude the object from all the lights GI and this is not what I want.
In my actual scene, there are several lights.
We’ve had a similar issue with our production. It’s caused a bit of a problem for us because of how we have everything setup. I’m curious if the fix you have for pixela would help in our case too. We have a bunch of characters with light rigs linked up to them and set to only include the characters they are linked up to. In theory it should work fine, but we’ve had a lot of issues like the one pixela has illustrated below. They’re illuminating things they shouldn’t; about 80% of the time it’s not a big deal, but in a few scenes as we get into tight spaces it’s been causing some issues.
I wonder if I could get some information from you, Vlado, on the fix you mentioned, and if I’d be able to get a copy of that fix too or if I could ask if there is any sort of ETA on when it’d make it into the main release of vray.
