If I use corona materials in the scene, the constant shader viewport mode looks all black.
Can confirm on my end too. Using Windows here btw.
This topic would probably be more at home in the bug reports section though ![]()
I wasn’t sure where the best place to post bug is - I thought Houska said directly here in daily builds forum?.. or do you mean this is not “just” a daily build bug?
seems the default C4D autolight (https://help.maxon.net/us/#45030?anchor=DIALOG_QUICKLIGHT) is also affecting the viewport in constant shading mode (which it definitely should NOT be)
The bug reports section is a bit more organized for us when we want to do bug hunting, however the reports there often don’t mention in which version the bug appears. This is implicitly presumed to be the current daily in the daily build section.
Both is fine. Do what works the best for you ![]()
Thanks for the report, we will have a look at it and hopefully we’ll support the flat shading soon as well.
(Internal ID=410801354)
yes, hopefully soon - it worked on v4, btw
Hmm, is anyone else also finding the Quick Shader to be simply too dark at grazing angles?
I have a fairly dark terrain texture and its literally full on black when viewed under grazing angles ![]()
Hey Nejc, would you have a testing scene for us? That would help us immensely, because we would then be able to test the new implementation against the scene to make sure it’s better.
So just for clearing this up for any other lost souls here… Houska received the scene files but it isn’t as much of a problem with grazing angles as it is that the new viewport previews are just darker than the native c4d material and their previews.
Hopefully that clears up my part
As for the constant shading, its pretty much black indeed.
