BUG: Random slowdown on scene parsing
So with the 19.1. daily I’m experiencing weird and completely random slowdowns when rendering a complex scene. Sometimes the render starts instantly, other times “Parsing the scene…” takes a minute or more, and sometimes “Building acc. structure…” takes a minute or two.
All of this happens without changes in the scene, ie. I press render and cancel a few times in a row, and each time the scene preparation behaves differently.
I’m using Max 2015.
Is it possible you ran out of RAM? If not, can you send me the scene (Renderer for architectural visualization - Corona | Chaos)?
I run a dual Xeon with 48 GB of RAM, so I don’t think it’s that. It’s not all that big of a scene.
It also happens when I isolate a single object in that scene and try to render. I’ll send you the scene after I finish work today. :smiley:
Scratch the “complex scenes” part. I just uploaded a small scene with three crappy trees with the link you gave me (1422293881_preparationslow.zip) . Same thing happens approx. 1 out of 10 times. Also the mat editor is insanely slow on in all my scenes, this one included.
Running Max 2015 on dual Xeons on a Supermicro MBO with 48 GB ram, SSDs, the works. As for plugins, besides Corona, we also have Vray 3 (SP1), ForestPack, RailClone.
I have an update:
I uninstalled and reinstalled service pack 3 for 3dsmax 2015, and it seems both problems are gone. Seems it was Max’s fault somehow. I did have SP3 installed before (no clue if the installation could have gone wrong somehow) but Max works in mysterious ways… :-/
Hope you haven’t spent too much time on it, or any for that matter.
ok, works fine here too. Let me know if anything changes.
Are there any compatibility issues between SP3 and Corona 1.00.01? After installing SP3 alla material slots went black!
I dont know about anything. It is possible max deleted something and your license got removed - check if it is ok
Already tried to remove Corona and install it again. Didn’t change anything. Before SP3 all was working.
EDIT: after rebooting the workstation it worked…mmm very weird.
