BUG - Rhino views using wrong lens length for batch output
I saved a lot view as favorites and try to get all views rendered per Enscape batch process, but the output doesn’t match the saved views. Please try to fix is soon as possible. The batch tool is very useful.
Maybe it’s the same like here: Rhino - lens length for standalone views ignored
Attached three views where the cube should be shown same sized in wide, normal and tele lens, but all views are shot per wide angle from the first shot during the batch process.
@Micha That’s basically the same situation as in your exported standalone files.
Currently FOV is a global Enscape setting which is not connected to single views.
But I put it on our agenda as it is useful for the batch export.
It’s a catastrophe!!! Please, don’t set it on the Agenda as a feature request. It’s more a bug.
Standalone views, batch render … both are useless often. For example at my current project I have 20 views of a complex interior. So I need to render them all manual now, since the views are well fine adjusted. And the views for the standalone? One lens length for all views. That’s hard.
Thanks for pointing that out. We will check what we can do there.
