Bug Splat
I am trying to render a scence in sketchup with vray. First i was exporting some test pics, to then adjust some reflections, lighting, etc. I am using 2 rectangular lights and one omni light (the GI sun is turned off because it’s an internal space and has no windows to the outside). Everything exported fine, like about 5 images. When i finally decided that everything was in order, y switched the output to 1600 X 1200. Then i pressed the “render” button and the Bug Splat screen appeared. I opened the file again and the same thing happened. I even restarted my laptop and the same thing happened. So i guess i’m stuck. What i noticed is that the error ocurred after i “adjusted” some materials. Does anyone have this problem or am i the unlucky one?
Re: Bug Splat
Please email me the file - I’ll see if I can track down whatever caused the crash. Does this issue happen repeatedly or was it just a one-time thing?
Bug Splat
hi, im from mexico, i have a same problem, when i try to render, a message appear, bug splat! what can i do? i restart my PC, save the file with different name, and nothing, i need help!!! please, my e-mail, juan_ant34@hotmail.com, thanks anyway
Re: Bug Splat
Maybe I’m wrong but…do you have a VraySky in HDRI?
Re: Bug Splat
Same here! the bug appeared after i added some objects.. good thing i saved it as another file before rendering. so i opened that old file, copy-pasted the additional objects from the file from which the bug appeared, hit render, and it worked! i thought i’ll get the bug splat again since what i did was merely a “replay”! so if its not the “additional objects” that caused it, what did? so we can avoid it in the future! help, anyone? thanks!
Re: Bug Splat
Try explode components and groups. I dont speak english. Sorry dont help more.
Portuguese.
Caso alguém fale em português fica mais fácil explicar a situação.
Também não consigo renderizar em 1600x800 ou mais, isso aconteceu depois de eu adicionar alguns itens no desenho. Infelizmente perdi o displencement da grama e de outros materiais.
Para resolver dei um explode em todo o desenho e consegui renderizar, mas não estou satisfeito, se conseguir outras informações vou compartilhar com vocês.
Re: Bug Splat
my prob is that after installing vray for skp.
whenever i tried to print preview using skp..bug splat appear
Any idea?
