Bug: V-Ray Switch Material on V-Ray Decal - V-Ray GPU
I tried to use the V-Ray Switch Material on a V-Ray Decal and it does not produce correct results when using GPU. I even build a test scene and the issue remains.
this is how it should look like with the working opacity.
this is how it looks when a switch material is used.
CPU doesnt have the descriped problem.
Hello @christian_schneider1 Thank you for letting us know! Could you please share with us the test scene you have created?
Sure thing @viktor_angelov
I attatched the scene. ​
TEST-Decal.zip (132 KB)
Hello @christian_schneider1 I have managed to reproduce the issue and have logged it into our system for further resolution [VC4D-2252]
Keep in mind that it does not occur if the renderer is CPU, if the Standard V-Ray Materials are used, if V-Ray Decal is not used. There are workarounds to create what you aim for.
