As title says - live link scene , change colour space to aces. Hit ‘render animated sequence’ in the Max Vantage tool bar – the scene reloads now and erases all settings back to default.
This is a bug that has happened since I updated to Vray 7 update 3 last night – also, the port number has to be manually updated. please fix these issues; the colour space in particular makes vantage useless for an aces workflow
Hi HeadOfficeStudio,
The reset issue is caused by the DR2 protocol and a fix for it is in progress and will be part of V-Ray(VMAX-15364), it is not on Vantage side. As a workaround you can try with a nightly stable build with DR1 , that should keep the render and color settings you have set in Vantage: https://my.chaos.com/download/build?..m-version=2026. Please test it and let me know if the issue is fixed.(Don’t forget to change the port to 20701 after you have installed the DR1 build)
Alexander
I just reinstalled the previous vray version for now, which works as it should… I had no time to test workarounds today sorry
