Bug: VfR reset lights during working per Rhino Render|Enscape
I’m working on a large interior space at Rhino 6. The render engine is set to “Rhino” and I use the Enscape output. In the background it’s installed the latest VfR3.6. I run in the issue, that the intensity of lights of different groups are changed without I touched them. It looks like there is an internal connection. I suppose so it is caused by the VfR light grouping/copying behavior. (I don’t know so much about it since I don’t used VfR3.6 in the last months.) I edit the lights on the second floor and later I see that the lights of the first floor shows the wrong light intensity. I adjust the lights on the first floor and later the lights of the second floor are using the intensity too. … Please check this issue. For now I disabled VfR at the Rhino 6 plugins.
-Micha
Hi Micha,
I did some testing and can’t reproduce the described behavior on my system.
Once you select a different Current Renderer instanced light links disappear and all lights become unique.
Can you list exact steps to reproduce the issue?
Konstantin
Hi Konstantin,
here an example file. Step-by-setp:
* disable the Vray plugin and restart Rhino
* open the example file and look at the red point light - it has a green light color
* now load the Vray plugin
* check the current render is “Rhino”
* now open the example file again
* during the load the lights are changed by Vray and the red point light shows a orange light color now
-Micha
Lights test.zip (819 KB)
Hi Micha,
Thanks for the steps list and the file.
I’ll get back to you once we test it.
Regards,
Konstantin
