BUG: vrimg not working in region rendering mode?
is it not?
I’ve been using the converter all day - i’ve got a scene that is so close to the memory limit i’m having to render to .vrimg format and convert to exr, but every render i do which is in region mode (for instance i just wanted the roof) it spits out an error -
Failed to write pixel data to image file. No frame buffer specified as pixel data source.
Only with the region renders…
Let me try and reproduce that here…
i can send you a file also if you need, i have one that is around 6meg…
Sure, if you have one ready, it is welcome.
