bug with brightness bellow 1 in matte and net rendering
Hello
Can someone confirm if this?
I have a plane with a box on top and a light source.
I want the plane to be matte (-1) and the box to cast a shadow on this matte.
If the shadow brightness is bellow 1 they disapear in all render nodes but not in the workstation that submited the job and where the manager is located.
If brightness is 1 then all machines render the shadows.
Can someone confirm this bug??
what version of vray?
also are there any maps in the scene? maybe an ies light?
Hi.
No materials.
I just made a matte plane (receiving shadows that affect alpha) and set the brightness to something bellow 1.
Put a box on top and a light source and send it to backburner.
Only this machine render the shadows, the nodes don’t.
If brightness is 1 all node render the shadows.
Can someone verify this?
I don’t know what’s causing this…
Is it something connected with the “.” “,” problem ?
I will check that out too.
nikki Candelero
Well, exactly as we supposed ! The problem is not in V-Ray, but that
“.” “,” decimal sign. Make sure all your render nodes are set with “.”
Then the rendering is going fluently with brightness of the matte set below 1.0.
nikki Candelero
Hi.
I forgot about that issue.
Nevertheless I already changed de decimal separator but the problem persists.
Did anyone reproduced this error?
Hm, strange :shock:
I could make it wrong and correct via BB. The difference was only the .
BTW, which BB is this ?
nikki Candelero
sorry…BB?
Bounding Box, Brigitte Bardot?? :smiley:
:lol: :lol: :lol: :lol: :lol: :lol:
BB = supposed to mean BackBurner.
Here are some other V-Ray / MAX abbs
__________________________________
DR - Distributed Rendering
BB - Backburner
IR - Irradiance
LC - LightCache
AA - Antialiasing
QMC - Quasi-Monte Carlo
CM - ColorMapping
List of some PhotoShop abbs
Mostly used when talking about layer adjustments:
LV - Levels
BC - Brightness / Contrast
HS - Hue / Saturation
CB - Color Balance
CV - Curves
SC - Selective Color
Feel free to add more to OUR V-Ray language :wink: :wink:
nikki Candelero
ah..:smiley:
I’m using BB 2.3
I tried opening max in a node and netrender from there.
The node renders fine and all others don’t, including this worstation that was working in the previous situation.
Any ideas? :cry:
I tested it in BB 3, MAX 8, SP3
nikki Candelero
humm…I’m a bit afraid of moving to max8.
What’s worst is that max8 can’t save as max7…only 3ds :?
Anyone willing to check this issue on max7? Please?
Ok…got it :sweat_smile:
Well…forgot that I have two users in the windows login
Changing the decimal separator in the correct one solved it.
Sorry…I’m not as fast as I would like hehe
:wink: :wink:
Good to hear that !
nikki Candelero
