bug with Forest pack (last version ) and Corona 11
Hello, we have a bug with Forest pack since installing version 11 of Corona.
When creating a forest object, the objects do not appear. We need to make a change of units in 3Dsmax, CM to MM, then the scatter objects finally appear.
Regards
Xavier
Does anyone have an idea of ​​the problem?
if I open a scene with an existing forest, there are no problems, only the creation of a new forest.
Regards.
Xavier
I use Corona 10 HF1 so I can’t tell. What do you mean by Corona 11? Are you using 10HF2?
Hi Xavier,
Which exact version of 3ds Max, Corona and Forest Pack are you using?
Can you share a simple scene where the issue can be reproduced, or share the steps so we (and others) can try it too?
You can always submit a ticket with any issue here:https://support.chaos.com/hc/en-us/requests/new
Hello, and thank you for your answers,
we use max 2024.1 ,ForestPackPro824 andCorona version: 11 (Daily Build Oct 3 2023) Build timestamp: Oct 3 2023 02:47:38 .
I can prepare a scene for you but it won’t do any good because when you open it, the forest will appear.
When I create the scene the forest is not displayed but if I close my scene and open it again, it is displayed. It also appears if I change units in 3Dsmax.
Regards.
Xavier
I have just created a very simple forest, simple max primitives, boxes, which I multiplied with forest on a plan. it works perfectly.
If I use my maxtree or globeplants library (these are proxies that we have been using at the studio for years) the bug appears.
Hi again xoudot,
Is the behavior the same with the stable release - Corona 10 HF2, or it happens only with the daily build of Corona 11?
Are there any updates on this?
