Hello, i have a problem with the v-ray texture, changing the color or brightness of the texture with a layer effect does not work either in preview or render.
Do you have a solution ?
Thanks in advance :)
Hello @victor_lambrun ,
Something isn’t right here. I will discuss this with our developers and will investigate it further. I will let you know if we have more information. Thank you.
When I have a issue like that (mainly when I work with 2-Sided Materials) I right-click on the material and click on Render Material. If this doesnt work, its probably a bug.
Hi @jonas_schneider ,
Rerendering the materials won’t help in this case. There is a bug and we are having an internal discussion about it. We will let you know if we have updates on the matter. Thank you.
