Bug with new frame buffer
something wrong with the new framebuffer
  1. Render the scene (framebuffer everything is OK)
  2. close the framebuffer
  3. Render the scene again, (framebuffer again everything is OK)
  4. close the frame buffer
  5. Render the scene again but framebuffer open as blank window
    Stage size does not matter. Helps only restart the application.
Sorry for my bad english
3ds max 2013 x64
Win 8 PRO x64 / 16 GB ram / Geforce GTX 670 with the latest drivers
Tried disabling nitrous or “progressive refinement” in viewport? (or whatever it’s called in max 13)
No. I can not work without a nitruos because of the strong brakes in a scene in which many polygons
But you could just try it to check if this solves your problem.
can’t it be a win 8 related? Rawa you got win 8 too? (if yes it might be some compatibility issues with wxWidgets vs win 8 or something keymaster could fix)
What is the status of the bug? I tried setting up a machine with W8 + gf660, but I cannot replicate the bug. Is anyone still having the problem?
Nevermind, reproduced and FIXED.
PS: Windows 8 is horrible…
This issue first came to me in version RC9, but I have sinned by not new video card drivers. Later, after the Alfa5 on 3Dcentre.ru many have encountered this. From my observation: it is more common when using higher resolutions 1500 (never had at 800/600), more frequently in the book page unauthorized persons (eg 1300/2000)
