I’m experiencing a strange bug with C4D 2024.2 and Corona 11. If I create a Physical Material and define a color, apply that to a default cube and add that cube into the Asset Browser, the material will turn grey after I load the asset out of the Asset Browser again. Does not happen with a Legacy Material. Somehow it felt like a Cinema bug and therefore I’ve created a bug ticket on their support site as well. But maybe it is something Corona specific? It is really really strange. We’re on Windows 10. Attached is a simple test scene where I can reproduce the error. bug_asset_browser_corona_physical.c4d (212 KB)
having the same problem, already wrote with the support team, they have created a bug report
the problem exists if the material is assigned to a geometry and open it from the assets browser.
if you save only the material, it does not happen. it should definitely be checked.
Unfortunately, I’m not able to reproduce this here as they load back in as expected. Maybe you can try creating a null and copy all the materials to that as well when saving it with your asset? At least then if the materials on the object load white, you can copy back the originals from the null.
Hi, I’ll be in touch again today, this error is really preventing us from storing data in the library (which is currently absolutely necessary for us). The problem is, you think everything is working because the preview etc. looks correct, but as soon as you render, you see that the material has reset, you can also see it when you check the data set for the material. I hope the error can be solved quickly, I think many users are not at all aware that this error exists and only notice it when they really need the data from the Asset Browser.
sorry for putting a bit of pressure here.
greeting
tuami
Hi there, as far as I can figure out, storing the materials to a null when saving your asset should fix them loading back in grey. If you can test this and let me know, that would be great!
we have textured this fire extinguisher with corona materials, then placed it in the asset browser. as you can see, the materials are not transferred correctly when you open the fire extinguisher from the assets browser. however, the preview shows that the materials are on it.the nullobject does not work for us either
hello we have updated cienma 4d to 2024.3.1 today in the hope that the problem will no longer occur (it could have been that the problem is caused by cinema 4d) unfortunately the error still exists and we can no longer place assets in the library as the materials seem to be reset. (The bad thing is that you think it’s fine, because the previews of the materials are displayed correctly, only after you put the objects from the asset browser back into a scene and look at the material properly, or render it, you see that it is basically just a simple physical standard material). The problem only exists with materials that are placed on objects, materials that are saved directly to the library - without geometry are recognized correctly)
We urgently need help with this problem!
win 11, last Corona version, c4d 2024.3.1
The data is on a network drive, everything else has already been explained a few times above
The bug happens on my side with 2024.3.2, but not with 2023.2.2. Corona 11h1 in both cases. All the material values are reset to default.
So does the issue come from Corona or Cinema ?
Also the generated Asset Browser preview is empty (black square) if the saved asset has Corona dependencies and Corona the active render engine (both conditions have to be met).
We’re waiting to upgrade to 2024 as long as we can’t use the Asset Browser and until today it didn’t bother us that much. But it seems that at least another problem we have with 2023 would be fixed in 2024 and this really would improve our workflow. For now, if we use Corona Bitmaps with the Asset Browser, a problem occurs where the Corona Bitmap is completely blank after re-importing the Asset out of the Asset Browser. The node really loses every ‘content’ (text, information, …) and is useless. After re-importing the Texture with a new Corona Bitmap node everything works fine again. (or after switching back to a C4D Bitmap node) At least it seems this is working in 2024 and that would be really nice to have.
Are there any updates if that problem could be fixed in the near future? Only with Corona 12 or is there maybe a chance for another Hotfix?
