Hello
Could you help me please
I get ramdom crash while i’m using substance shader (displace + normal bump)
I can not find the cause
_BugReport.zip (57.3 KB)
Hello
If that is the Substance map in the 3ds Max Material Editor, there is a known limitation where it may cause crashes - https://coronarenderer.freshdesk.com/support/solutions/articles/5000516180-known-bugs-and-limitations (search for Substance on the page).
“Substance map may sometimes cause problems” outchhh, i’m feel good now
Tom, this is C4D bugreport ![]()
Seems I still have to be more careful with the Unread Posts searching!
Hi, I would like to ask you whether CoronaC4D Alpha 6.3 Corona for C4D A6.3 testing - Corona for C4D :: General - Chaos Forum solves your problems with substance shader?
