Bug - X to close VFB before saving finished = max closes
Hi folks,
Simple but bad bug - maybe one more to do with max rather than vray?
To reproduce:
max 2014 latest SP
latest stable vray
- Start saving the VFB out to an EXR (formal probably irrelevant), but hit the X to close the VFB before it’s finished saving the file
- Instead of only the VFB closing when the file has saved, the whole of max closes. No crash screen is given. It closes as if you chose to hit the X on max itself.
Thanks,
Yeah, I can see why that would happen :slight_smile: Will make a note to fix it.
Great thank you!
I’m trying to reproduce the bug, but it does not happen. While saving the X button is disabled and I try clicking it constantly. When saving finishes the close button becomes active and on the next click vfb is closed normally.
Could you give more details, please.
Thank you,
Svetoslav Popov
Next time I’m in front of my workstation I’ll take a look. But it’s just as you describe. When rendering is finished and the output is being written, hit the X on the VFB and nothing seems to happen. Once the file has finished being written the whole of max closes with no error window or anything. I’m pretty sure that’s the steps. I will verify as soon as I can.
