Bugs in corona installer for mac / cinema 4D
Hi there,
I tried to install corona on our team render environment (mainly equipped with mac pros - but also some PCs/win7,win8,win10)
Only one of the macs runned corona in team render mode - all others did not show any activity.
I then noticed the following:
  • If i run the installer on a machine, where only a team render client is installed (the recent and an older one), it asks me, in which version i want to use corona - which i answered with the newest version (R18 in our case). It installes the plugin then to the oldest instance of team render.
  • If i run the installer on a machine, where there was no older instance of teamrender before, it creates a folder for «Cinema 4D R18» instead of copying the plug into the existing team render client PlugIn folder.
  • If i have a full installation running (combination between full C4D and Client) – and only of the newest/one version, everything goes well…
After copying the plugins from their wrong folder to the correct (team render plugin folder) everything works pretty well.
I hope that was clear enough to make my issue understandeable.
Thanks,
-Stepha-
moving to C4D bug reporting
