Bugsplat when importing alembic file
Hi
I made a tree using Sapling addon in Blender(Which could generate animated trees),and export an alembic file(72 frames)
I want to animate the tree in Vray for Sketchup, so I import alembic file with Vrproxy importer
Actually I can import the tree
But when I hit render,It crash
I could already import a simple cube and animate it,but no have no luck with a tree
Is there any info about how large a file Sketchup could handle with?
Thank you very much
File attached in the link below
Sketchup 2017
Vray for Sketchup 3.4.04
VrayBlender 35
Windows 7
Ryzen 1700X, 32GB Ram
Dropbox - Tree.abc
BTW
It seems like Support@chaosgroup.com block my email address
I send email several month ago without any reply
Can you check your spam folder?
Thank you very much!
Animated proxies are not supported in V-Ray 3.4 for SketchUp. This, however, does not mean it should crash upon rendering. We’re adding animation controls to proxy objects in the upcoming v3.6. Will double-check your file in our internal builds to see if I can reproduce the bugsplat in any way.
Thank you for reporting this!
Regarding our lack of communication, we have not heard from you since my last reply on June 14th. Truly sorry to hear you were not able to contact us ever since!
Could you please follow up on the private message I’ve sent you?
Kind regards,
Peter
Hi,Peter
It is a great news that we could have better animated proxy control
The only problem I have now is vrproxy export from blender is extremly slow.. so I’m really curious about will Vray add better alembic file support?
just my 2 cents
Proxy support in general has been improved in v3.60.01.
We know certain animated .abc files might still crash SketchUp upon being imported. If you happen to reproduce this, please send us an email at support@chaosgroup.com . Any step-by-step description of the creation process of such problematic .abc files would help us tremendously!
Kind regards,
Peter
