Hello!
Have an issue with Building acc. structure process. In scenes, where this process takes normally few seconds from time to time it starts to take 1.5 - 2 minutes instead. Even if I do not change anything, just click render and stop buttons I can get so different times for Building acc. structure in about 50% of cases. It doesn’t depend of amount of geometry, HDRi or anything else what I tried to change…
I’ve noticed it working with Corona 1.4, but with newest builds (2016-07-12 currently) I have the same picture.
Max 2014, win 7
can you create few minidumps while it is happening?
(see “2. Reporting errors or freezes if Autodesk Error Report window is not available” for instructions how to create minidumps)
https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
Hi
Uploaded minidumps with privat uploader (1468475615_minidumps.rar)
There 4 of them. 3dsmax-o is for the case when Building acc. structure took 1min 15 sec, others took 2min 15-55sec
Thanks for the minidumps, it is just as I suspected, memory deallocation problem in embree.
- Does it happen on all your computers?
- By any chance, are you running 3dsmax under debugger? Or using any system utility that could interfere with memory management?
- Can you check if fault tolerant heap is turned off, just in case?
- Can you post the screenshot of your memory tab while this is happening?
- If it happens on multiple computers, can I have the scene to analyze it?
Sorry, was busy these days, didn’t have time to answer earlier.
I have only one computer with Corona
No. I didn’t run any utility myself.
It’s on
It’s attached here (taken time was 53sec instead of less than 1sec)
I have only one computer with Corona ![]()
Some notes
Next day after I’ve started this topic I tried to catch the problem to make minidumps: I launched all the programs, aplications which I can start at the same time with 3DS Max, connected different divices to computer, but whole day rendering went smoothly and this problem didn’t appeare at all. I already started to think about some magic from Keymaster, but yestarday, when I had deadlines for two projects this issue happend in 95% of renderings - that was terrible because I had to make lot of test renders. Worst result was 5.5 min in the same file which I used to make minidumps. And yesterday I avoided starting unnecessary programs, restarting computer didn’t help either…
Hope you’ll find the point why it happens. Thanks in advanced!
Yesterday upgraded from Win 7 to Win 10 and this problem has gone! Suppose that the problem was connected with not updated Windows for about two months.
Now Building acc. structure takes few seconds as it was earlier.
Thanks to pokoy for sharing his experience (Building acceleration structure - what does it depend on? - Corona for 3ds Max :: Help Required - Chaos Forum), and to guys from this topic Windows 10 - how to avoid an upgrade - Common :: Off-topic - Chaos Forum !
Restarting my computer helped take away this Building acc. structure issue.
