Built in "Skatter" type function for each mouse click when placing an object
I’m sure you’re aware of the excellent plugin Skatter (www.getskatter.com) and what would be great is if there was something we could turn on (and set settings for) so that each click to place an object slightly manipulated it.
For example it would randomly:
  • increase or decrease size +/- X% (where X was set by user)
  • tilt on the Z axis by X% (i.e. so not perfectly identical)
  • randomly rotate the object from 0 to 360 degrees
I’m not suggestion you go and build something like Skatter - it does a great job and integrates wonderfully with SU and VRay - just something that creates a modified instance with each mouse click.
