bulletproof animation settings with lightcache
do they exist? ive got a scene with animated geometry, and i need it to render error free first time! -im using vray RT gpu.
obviously i could do bf/bf. but the rendertimes are impractically punishing.
the recommended settings for lightcache (set retrace to 8 ) render faster, but i see some small flickers.
should i just turn retrace even higher?
ive also set the lightcache to 2500 subdivs.
normally id use “use camera path” to help with the static areas, but as mentioned in another post, its greyed out when using rt gpu..
ive also tried setting the secondary gi to “none” and , strangely it doesnt look significantly different, but, its also way noisier and actually takes almost double the time to render as that with the secondaries set to lightcache.
What kind of flickers are you getting?
ahh just little blotches in the corners here and there.. in my own way i have resolved it. ive hidden the moving objects (they are quite small) calculated a flythrough lightcache for the scene, then unhidden the moving objects and rendered.. this , according to my tests, renders clean. and not noticeably differently, unless you are comparing side by side with a sharp eye. . Obviously the animated objects are only illuminated by direct light and one bounce of gi, but since most of the rays from those objects hit the static geometry which has the lightcache precomputed, they get almost a full lighting solution..
do you see any drawbacks to this solution apart from a lack of perfect physical correctness ..?
