Bump and round corners issue
When round corners active (have a non-zero numeric parameter) - a bump is disappeared. In attachment It clearly visible on brick part of object.
Exterior scene, used corona sky and corona sun. PT and HD.
So round corners is probably executed as a bump map, like in mentalray?
May be like that) But MR has 2 bump slot (at least in Maya). May be in CR it is not a bug but unfinished feature)
it is a bug (I think I’ve fixed it approx. 5 times ;))
I’ve search around “Bug Reporting” topics and haven’t found about, so create a post. Sorry if repeated)
Maybe I should ask for access to Mantis)))
Don’t worry, it was reported internally in earlier stages of Corona :wink:
Fixed
