I’ve noticed that bump maps are no longer working. I’ve tried turning bump mapping on and off and adjusting the bump multiplier and nothing seems to work. Perhaps it’s a driver issue? I’m using an RTX 2070 Super with 456.71 installed.
Did this start happening after switching to V-Ray 5 ?
Greetings,
Vladimir Nedev
I don’t believe so. It may have been after hotfix 2. I was going back to play with an old scene that was definitely working with Next.
I’m also running into this issue…rug bump or displacement does not transfer over. I’ll have to check which one. Using max 2019 and vray 5.
Hi Luma3d,
Displacement is currently not supported and also procedural noise and normal maps are not supported for bump. If any of those are present in your rug material it will not show with a bump.
Alexander
