How to use a bump map on a layered material ?
On which layer should I plug it ?
For example, with Vray, I can plug a Vray layered material, into a Vray bump material. Then the bump map is like added on top of everything.
What would be the right approach with Corona ? Maybe to plug the bump map on the last layer ?
You should plug bump map into each sub-material which needed it. If you want just one bump map all over blended material, then maybe there’s no need to use layered material at all? I can’t count how many times i saw Vray users use Vray blend material just to alternate between different diffuse colours. That is very ineficient way of using materials.
I would like an option of blending normals from layers myself. I think Maxwell worked like this, and all real-time engines offers this choice when using BlendMaterial.
Coat material could either take on base normals or overlay them together. Currently it only alternates between them unless manually input in all sub-layers, but this destroys the instanceability (uh..that prolly isn’t a word) of layers, which should ideally stay untouched.
In such case you just apply bump to the coat layer.
It should be quite easy to experiment with the materials and draw conclusions.
If you have bump on base and layer1, then you can just blend between the materials.
Some exceptions here are displacement and SSS - they are always taken from the base material (AFAIK always).
