Bump mapping makes objects look faceted
This should be better in the latest nightly builds and for the 3.40 SP in a few days.
hi vlado,
when can we expect 3.40 sp ? in this month? or more?
The plan seems to be for the beginning of June as we have some official holidays coming up at the end of May. But if you need this fix sooner, we can get you a build.
looking forward to it
thanks for quick anwser. I can wait, just asking.
Can I seomewhere see confirmed features/improvements listed for the new SP?
A small partial list off the nightly builds looks something like this, but it doesn’t show everything:
*) VRayDenoiser render element that allows to calculate a denoised version of the image, optionally the denoiser can run on GPU;
*) Somewhat faster rendering with brute force+light cache combination;
*) Faster rendering of 2D displacement on flat geometry; removed the “precision” parameter;
*) Further optimizations for rendering of proxies;
*) Better sampling for GGX/GTR BRDF type;
*) Changing the VFB region during interactive V-Ray RT render does not restart the whole image;
*) Show GPU usage statistics (GPU load and memory) for V-Ray RT GPU;
*) Reworked VRayLight user interface;
*) Support for procedural Noise and Mix textures for bump mapping in V-Ray RT GPU;
*) VRayStereoscopic helper supports vertical placement of the views in addition to side-by-side;
*) Lower tessellation rate for out-of-view hair and displaced/subdivided geometry to save RAM in heavy scenes; “static geometry” is enabled by default for displacement;
*) Stochastic flakes improvements, added colored flakes texture;
*) VRaySun and VRaySky - vertical offset setting for the skydome, control of the ground blending;
*) Enable high DPI support for the V-Ray frame buffer;
*) Enable GI by default;
*) The V-Ray scene converter converts rectangle/sphere/disc photometric lights without web profiles to the corresponding VRayLight’s;
*) Moved VRayHDRI’s Tiled textures options from the material editor’s interface to the global switches rollout;
*) Support for MultiTile in V-Ray RT (3ds Max 2017);
*) Support for ColorMap in V-Ray RT (3ds Max 2017);
*) Add “layers” type to override material exclude list;
*) Show progress bar instead of “not responding” during export to .vrscene;
*) Added a refraction filter bake element;
*) Added another deep fragment merge mode, “None”, where fragments are not merged at all;
*) When auto-saving images to the VFB only auto-save if the render completed normally (i.e. is not aborted);
*) Add an option to keep the VFB history folder relative to the current project path;
*) Improved slow rendering of objects visible behind multiple panes of glass;
*) V-Ray scene converter should convert the 3ds Max Normal Bump map to VRayNormalMap;
*) Warn the user if all the GPUs they have are used for RT GPU;
*) Enable support for processor groups by default (more than 64 cores);
*) Bring back the V-Ray exposure control;
*) Make the DR settings window with persistent size (keep size between 3ds Max sessions);
*) Add information about the current noise threshold to the VFB statistics for V-Ray RT;
Looks promising :slight_smile:
Wow, looking forward to it, really nice improvements!
Superb as always! :slight_smile: Vlado, just a quick question in case to have the information to hand - know the GPU team have been working really hard on the bump and procedural side. Have there been any improvements in matching the beauty pass between Adv and RT GPU (cuda) for bump/normals for Max? And is Stochastic implemented on GPU on the update?
Many thanks as always Ben
That s a small feature but man…
I love pg skies but there is always the problem that we see the black horizon due to the cut in the HDR.
So glad to have that option :). Thanks !
exposure control is back!
I don’t see how the two are related?
Maybe I missunderstood but if a vertical offset of the texture is now possible I can get more sky and less black.
I don’t have to try to hide it someway.
Yeah… thought you could already change the rotation and offsets of a spherically mapped HDMI.
Yes but if you have an animation in the middle of the ocean with no island. That won’t work.
The changes are related to the VraySun and VraySky skydome, so nothing to do with the VrayHDRI map. Offset, tiling, is already possible. If you want less black I suggest adjusting the tiling (never tried it, but should work).
Edit: just tried, it doesn’t work :slight_smile: But you might just stretch or paint some extra sky in photoshop if necessary.
Edit2: what might work without photoshop is use Crop/Place and set Crop in the V direction to something small like -0.02. But that results in black hole at the top, so not really ideal.
This problem still appears in Vray 3.40.02? I’ve got a normal map that I’ve got too boost to get a better definition but I’m getting faceted polygons instead :frowning:
make sure you are not gamma correcting the normal map. It should be set to 1.0
Yes, texture gamma is 1.0, not 2.2. That’s actually the first thing I checked.
