In my bump slot I’m loading in a bitmap with a gradient. However when it’s rendered it looks like its “unfiltered”. I’ve tried various options within the vraybitmap material, but nothing is helping. I can increase the blur value, which kind of hides the issue, but it’s not really a solution.
This happens on various bitmaps, and the bitmaps are high-res.
I’m trying to use bitmaps over procedural, as I need this to work in Vantage too.
They should be filtered based on the Filtering settings. I presume its their color depth which is the issue. Otherwise, you can easily rerender a Radial gradient ramp by right-clicking on the procedural texture and clicking “Render Map”. It takes a second.
I’m really not sure if the filtering is working as it should. I’ve swapped to another bitmap, with black and white, no gradient, and you can see the artifacts on the render.
Also, in the Global Switches area, ticking / unticking the Filter Maps doesn’t change anything.
You are correct, these will be jpg artifacts. However, unless my memory is failing me (which is probably happening!), I thought the filtering on bitmaps was meant to prevent issues like this? At the moment the filtering doesn’t appear to do anything.
Yes I agree, re-making the bitmaps in a lossless format would probably help, but that’s not always feasible for many projects.
In the VRayBitmap node, there’s a Filter multiplier - pump it up, and you’ll see it works. It’s meant to help out by “anti-aliasing” the texture; it can’t magically clean low quality maps.
