Bump on Rhino ground plane not working in GPU mode
… but in CPU mode. My workaround - normal mapping works for GPU. Attached my test scene.
InfiniteGroundplaneBumpGPU.zip (618 KB)
Hi Micha, thank you for noting this - we are aware of issues with bump texture mapping and GPU rendering, and we’ll have a look at this case as well. We would recommend using a regular surface instead and stretch it as much as you desire, which you can then map to your needs. Generally Infinite Plane/Rhino Ground Plane should be used with simple texturing.
