The value setting for Bump mapping is all the way down to the bottom, while this is one of the settings I changed the most. It’s really annoying having to scroll down while, for the most time, I only work with the top settings. Can there also be a setting for Bump mapping at the top of the materials settings?
Hm, my screen is only 1280 px high, but i don’t have to scroll anything, parameter editor fits in its entirety, as long as i keep volumetrics and advanced rollouts closed, which i do most of the time. I like where bump map is placed, so i think, i will downwote this request, sorry.
I’ll try to motivate my request a little bit more. I work as a freelancer and therefore I often go to clients to work there. They almost never have a second monitor to use and so I’m tied to a single 27" screen. As you can imagine I’m constantly moving windows around in 3ds max to manage my workspace and therefore try to keep them as small as possible. That’s why I was talking about scrolling.
But even though most of us probably have two screens and don’t need to scroll, it still doesn’t make sense that there is one frequently used setting that’s all the way at the bottom, useability wise. Why isn’t this more at the top, next to Reflection Glossiness for example? These two settings directly influence each other, so to me, it makes complete sense that a setting that is often used is in a place where it can accessed easily and is next to a setting which it’s related to.
Thanks! I’m hoping you can give it a place under the “Basic Options” tab, and not the “Maps” tab. But I guess you have to reorder some stuff and I’m guessing that’s not preferable..?
Yes exactly, or Refraction for that matter, that almost never uses a texture.
