Is it normal that you cannot see a bump effect when using only skylight for lighting?
here’s n example:
with direct & skylight together:
with only skylight:
here’s n example:
with only skylight:
Yes
/Thomas
Yes, I think so! And its good in this way, just try to use Vraydisplacement and youl will see the difference in render time with the irradiance map calculation.
Gonçalo
the real problem is:
it would need a much higher sampling and therefor produce more flickering.
robert
You need some diversity in the skylight color in order to make the bump visible - make one part of the sky darker than the other, for example, or simply add some objects to the scene to block the skylight in certain directions. This is because the geometry is, after all, flat; if the skylight is uniform from all directions there is nothing that would make the bump map visible.
Here are some examples:
uniform skylight: bump is not visible
non-uniform skylight (checker map), some bump is visible
uniform skylight with another object in the scene, bump is clearly visible
Hey thanks!
bumpmap & skylight
Try using Comosite Map with two different HDR images for environment.
It gives dramatic improvement in rendering bump maps.
Experiment
Regards
Pera Zdera
[/img]
Hi, your experiment doesn’t show up here.
regards,
flipside
Same here …
Regards,
Nenad
Which experiment? I can post the scene as well, if you want to check it out…
There was slight misunderstanding.
When I said experiment I was thinking that one has to experiment and to some tweaking with different settings (multiplier etc.) for HDRi images which constitute Composite map.
I didn;t plan to post images because I don;t have permanent web space. I’ll try to put images now. ometimes they will be on… but sometimes off.
Environment with Comoposite map
Environment with simple HDR image:
Material Editor screen grab:
I used override of MAX environment setting in VRay render dialog
Hope it works now
perazdera
2 perazdera
I can see only a red X
please change the link
I’d like to see your tests
bye and thanks
Hey Pengo, as perazdera said in the post prior to yours:
“I didn;t plan to post images because I don;t have permanent web space. I’ll try to put images now. ometimes they will be on… but sometimes off.”
-dave
