I’m not sure this option is not , but I can not find it.
In other render engines you can disable all displacements at once with a button on the menu render, and then reenable easily, without having to go to each material or objects with corona displacement modifier…
Thanks and regards
First tab of the Render setup dialog —> disable displacement
I was sure it would not work with the displacement modifier and I was looking at the menus of Corona and I did not think to test the basic button of 3dsMax…
Thank you very much and I 'm sorry I wasted your time ![]()
