buying a new pc need suggestions!
im buying a new pc but im not sure how much ram ineed i just want a fast viewport and render xD wht really does ram/ prossesor do? any pc recomended? thx in advance
well it all depends how much you are willing to spend. but for a mid-range Workstation, i would go for a AMD mp dual machine… on a Tyan tiger motherboard with 1.5 - 2 gig of ram .. a good Nvidia card ..you dont have to spend a fortune to get a good running machine.
thx natty does the amd get hot too fast? i always have used intel and have afraid to move to amd XD
hey Zuli,
no…I’ve used AMD almost exclusevly for the last 2 and ahlf years and never had a problem with them, even when rendering for 48 hours straight at 100% usability…always realiable.
I would definatly go w/ AMD if you don’t have that much money to spent, and put your money into 2 gigs of Ram and a nice 128MB nvidia card…you should get a kick a$$ system…
then only reason I would even consider going w/ Xeons is the ability of hypertreding…but seeing the issues that many people seem to have run into, especially w/ animation…I wouldn’t count on it 100%…althought I use dual Xeons at work and I did see a 25 to 30% speed increase w/ vray…haven’t really tried them on a heavy-duty animation so I can’t say I fully tested that…
in the end, i think AMD athlons will give you more for your buck, and allow you to invest in a nice amount of Ram and good Vcard…
paul.
AMD’s are great.
The intel Xeon’s are good as well.
Get atleast 1gb minimum, 2gb or more is ideal. And go for an Nvidia card as they have better openGL drivers which is what the viewport uses. True they can Directx but its no where near as good.
It all depends on the money.
Best
Dual Xeon 3.2/3.4 ghz with 2gb ram of Corsair RAM
Nvidia Quadro FX 3000 would be the best but they are like $2000 cards best to go with a Good gaming card FX 5900 Ultra or something.
Good Asus motherboard or something similar.
Good value
Dual Athlon 3200 or opteron 2gb ram
Nvida Card as above.
Also good Asus motherboard or similar
Also the only that thing makes the viewports fast is the Video card, sure if you have a crap machine everything will be slow, but VC is important for viewport display speed. For rendering only RAM and CPU are important.
Also AMD’s dont get to hot, thats a crock of sh*t. They are fine, infact the new Pentiums are far hotter!!
Basically any CPU will get hot unless its cooled properly. And it needs to be cooled depending on use and environment. If you live somewhere HOT and you want to overclock, then you will need a much better coooling solution than someone who lives in the arctic …heheheh
True to some of the comments above.
AMD is much of a choice when it comes to saving a buck or 2.
But dont put aside Xeon just yet. The price of Xeon has gone down dramatically.
The reason people have problem with hyperthreading is still uncertain…but what about those who has not encountered any problem.
I think you should ask a few people who uses hyper and get their setups or configuration.
i bought mine in febuary and have not switch off the machine ever since except for upgrading my disk drive.
from what i hear on this forum…if youre going to use Xeon…you either use Intel or Tyan and even Asus PC-dl Deluxe motherboard…just to be safe. im using intel and no problem so far.
AMD are prone to overheating and locking up. I have a dual Athlon 2100+ MP workstation here, and even though it sounds like a jet engine because of the seven fans it still locks up occasionally when rendering for long periods of time, especially in the summer. It’s not a huge problem, and it happens very rarely, but you should know about it.
By the way, when rendering in the winter it’s a great office heater! The air comes out of the case at a comfortable 45° C :slight_smile:
yeah as long as you keep em cool you shouldnt have a problem…
The problem is keeping them cool :wink:
Crossbow (Greg Hess) was the one who helped me add extra cooling to my workstation. He knows his stuff, and his solution works well 99% of the time, it’s just those hot-day rendering sessions that still lock them up occasionally. The cooling that came with the workstation was ridiculously underpowered, and it froze up all the time.
mmm i have an athlon 2700 here, which is overclocked by about 10%. I have an aftermarket heatsink and fan, and its never gotten of 47c. That was in summer when my room temp was above 30c. And its never locked up because of that. And its also fairly quite, i have an aluminium case which helps keep the heat down as well.
The main deal with keeping the AMD’s cool is the CPU heatsink and its fan. As long as they work well then the case fans dont play as bigger part. If you have a basic heatsink then the case fans play a bigger part. Thats the way i see it anyway :slight_smile:
The money you save on getting an AMD, you can put it towards a decent heatsink and fan anyway.
I would recommend getting after market CPU cooling no matter what you get anyway. As it just lessens the chance of having heat problems.
So i guess it comes down to how the case is design have the layout of its contents. Plus not using the stock heatsink :slight_smile: that is probably the biggest factor hehehehe
It is true that the older AMD’s were little hotties, especailly yours Egz. But compared to the INTEL Palaminos today, they seem quite tame.
True, I’ve had this workstation for 2 years now so the age has a lot to do with it. I’m going to demote it to render-slave soon and get a new workstation. Which is why this thread is pretty interesting to me too.
forgive me for budding in…maybe we should come up with a benchmark to help him choose a processor…
heat to me is not a problem…what is important is to be able to render a fair scene with less than 3 hours. the less time to render the lesser time the computer will need to work.
to me a good casing will take care of the heat.
these days, I would go with AMD and use the extra money for ram. 1 gb is nearly not enough these days. My next machine is going to have at least 2 gigs. When dual core chips come out, it will knock the socks off hyperthreading.
hey thx its just about a scene i cant add meshsmooth 2 much polis and vray say unhanded expetion i dont know if is ram but the viewport and max just cant handle it too slow so i was thinking on a dual but not too expensive i have never tried amd but if u say ill try i also was looking for a BOXX but i really want to know
ram is usesfull for what? calculation boots rendertimes?
prosesor
and i want a quadro card too
thx for the info guys
:shock: :shock: :?: :?:
can you elaborate?
paul.
both amd and Intel are developing dual core processors that have effectively 2 processors on one die, each with their own cache.
zuliban:
BOXX are good but pretty expensive. Your best bet would be to buy the part seperately and get someone you know how is good with computer to put it together, you can save quite abit. But depending on your situation and money levels may as well get a BOXX.
Ram, is “basically” high speed temporary storage. Programs put things into the ram as its quicker to access. So when your rendering it will allow max to access all it needs via the RAM, if you dont have enough ram it starts getting it from the harddisk which is much much much much slower. So you want to get as much ram as you can afford. It also depends on how much you will need as well.
More RAM doesnt necessarily mean that you renders will be fast. Especially on smaller scenes that dont use that much RAM. Like if you render a room full of teapots the RAM usage might be 300mb, so no matter how much RAM you have aslong as you have 300mb it will render the same (excluding system overheads..etc.). Now if your scene requires 2gb of RAM, and you machine has less than 2GB it will start accessing the harddisk and slowing the render down alot, where as if you have more than 2GB of ram then its quicker as it accesses it all thru RAM. So more RAM wont speed things up unless your running out of RAM on big projects and it starts accessing the harddisk.
So if all your do is simple to moderate scenes, you could get away with 1.5gb or so of RAM, if you plan on doing big complex buildings or scene with lots particles and huge textures (for example) then you would need more RAM.
Now RAM also helps general windows running as well, also makes a difference in Game load times. For instance my friend has 512mb , I have 1gb on certain games i will load a level 30% faster its pretty handy.
So yeah, more RAM is helpfull in certain situations in rendering but it all depends on the type of work you do. I always say get as much as you can afford without sacrificing more important items like CPU.
About the Quardo card, like i said earlier it may not be worth the extra money. You could get a high end gaming card and be damn close in terms of performance, and save lots of $$$ :slight_smile:
I used to have problems with AMD’s heating up. I guess my case was designed poorly. So I took my side panel out and put a house fan to it, $10 fix. Cooling problem solved. :smile:
hmmm
i’ve seen this “amd’s run hot and get unstable” comment alot, online and from friends, yet in our farm of literally hundereds of amd chips of all types, we dont have many overheating issues as long as the room stays at a reasonable temperature. and the intel chips overheat too, which stands to reason considering they output alot more heat.
everytime i hear of someone’s chip overheating, legitimately, not just hearsay, i just shake my head. often times they have usually installed some fancy aftermarket heatsink in a glowing neon chassis.
if you buy an amd cpu retail kit, it comes with a heatsink. a boring non led lit, ugly heatsink. this little thermodynamic marvel was DESIGNED for the chip in the box with it. in an appropriately designed case in an adequately ventilated room, it WILL keep your processor running flawlessly.
there are of course several people who use this heatsink and run into issues. just like there are people with overheating xeons. you know what the simple solution is? make use of that 3 year warranty and RETURN it. it’s DEFECTIVE. this happens. amd would not release a chip with a fan that is not adequate. neither would intel. if your chip does not run at the specified environmental conditions, which inclued the boxed heatsink, then you have a chip that doesnt meet spec and should be returned to amd so they can provide you with one that does.
make sense? good.
about ram.. on a 32 bit system assuming you have the 3gb switch on xp enabled, 2gb is about the limit for ram being usefull. more than that and its either unused or make the system a bit unstable. all our machines have 2gb. without the switch, say if your running 2k, 1-1.5gb is the sweetspot, 2gb seems to again make things a bit unstable. there is a thread here somewhere about this.
on processor speed, i find amd opterons to have a bit of edge over xeons on most rendering, but in some situations, like using scanline, this can reverse a bit. hyperthreading by most accounds is a bit flakey with max, and when it does work, does not seem to provide a huge speed increase. it seems that the more multi-thread optimised an app is, the less ht makes a difference.
i personnaly like opterons, if only for their future proof quality. you wont need to chuck it as we get more and more 64 bit apps.
on video cards for fast viewport performance, the quadro 4000 seems nice :slight_smile: even with some flakey drivers though, nvidia cards always seems to me a bit better than ati for max. especially in opengl (i cant stand direct-x). i’d personally get the fastest nvidia card you can afford.
hope some of that was helpfull.
later
hi all
@home i have a dual AMD 2 Ghz with 1 gig memory and a fast ati card
@work i have a dual xeon 3.2, 2 gig memory and a fx3000 with 2 19" panels
what i can say… the workflow with 2 gigs and the Hyperthreading on the xeon is a lot better then on my AMD
but for the price of the xeon i can buy 3 dual amd’s !!!
is all about price !
when you dont have time to play with your machine… because he overheat and all other little problems… buy a DELL workstation…
/.mario’
