this is my last work, hope you like it!
Sweet, any chance for that pano in an âinteractiveâ version? ![]()
voilĂ
http://theviewer.co/share/40acb36a-32bb-4f98-a73e-02ad6e41cf3c/63d2b27e-fc7e-40eb-8ba4-39ffd10a3a51
i cant understand why there is a pinch at the the top/bottom of tyhe imageâŚand also a strange line behind the starting point of viewâŚ
For some reason it only shows a black screen for me. ![]()
About the pinch/artifacts - did you have your camera levelled? (no rotation other than Z axis)
The line behind the view - were you using bloom & glare? Those wonât currently work across the âseamâ of a pano (one seam in a spherical mode, multiple seams in cubemap mode). The pinching is most likely due to the spherical mapping, that will happen at the poles - as you can see in the âflattened outâ version, the top and bottom of the map are very stretched and distorted when using spherical mapping. That could be avoided using cubemaps (though note that at present, cubemaps arenât supported in the Corona VR app).
i tried to reload the image
http://theviewer.co/share/antoniomanzeni.00@gmail.com/63d2b27e-fc7e-40eb-8ba4-39ffd10a3a51
hi,
thanks for the help, i thought too that the cause of the line was determined by some postpro made by bloom&glare/Lut/curveâŚsome time ago when i was trying to do an hdri i saw this tutorial (around 4:10min there is the point)
for ptgui, and he explain this problem of postproduction done in a spherical imageâŚmerely the sides of the image are not treated equally
