Hello everyone,
In vray there is a layer material weight, that generates the alfa kanal. Does anyone know if is possible to create the same in corona?
Thanks.
Hello everyone,
Thanks.
put rgb texture in Diffuse slot. then tick “Opacity” tab and put there the same texture inverted black and white(add filter and enable clipping to invert it and make Low Clip - 100% / High Clip - 0%, put gamma to 0.1 (lowest) and it should make alpha smooth and clear. that should give you alpha effect).
