C4D animated textures
I loaded an image sequence into my C4D material. When i render the single frames in the viewport, everything is working. But when i try to render them in the picture viewer nothing is happening. It is always rendering frame 1. Is this a known bug?
No solution out there?
I’d love to help but I don’t have a clue on this one so I am just bumping the thread a little :smiley:
Thank you. :wink: The external Material is actually working. So I used the standard C4D material for it. But when you put your alpha video into the alpha channel in the C4D mat, it is not working. You have to use the transparency channel.
Solved.
