Does anyone know why for one of my scenes i’m working on the camera option for both the cinema camera and the corona camera tag are greyed out?
I think it has something to do with what VFB is saying about the settings are synchronized to a camera? How do i unlink it?
Thanks, appreciate any help.
i found out you can right click and overide any parameter still would be good to know what may be causing the issue? Thanks
You are probably using takes.
Check in the according tab.
as Cinemike said, you probably have Overrides Locked in the Takes manager. It is by default located in the top-right corner and disabling “Lock Overrides” should do the trick for you.
Let me know if this helps,
Jan
