C4d - Corona - Edge Trimming
Edge Trimming only works when a corona scatter is not placed within a null.
Once you make it a child of a null, edge trimming doesn’t work. This seems to be the case in R25, not tested other c4d’s as this is the most stable for me.
Hi there, I can’t seem to reproduce this here. Can you share a screenshot or a working scene file?
Hi, Thanks, i’ve just tested this after work, it’s actually just to do with our default scene setup. The issue seems to be to do with Null saved in the default scene (I.e what i am calling a legacy Null). I think i will just need to do an update to our start scene. Just sending this so you don’t need to investigate further! plus anyone else who may have this issue.
Cheers
Chris
