I would like to report a long-standing performance issue when using Corona Renderer in Cinema 4D, which significantly affects usability during material editing.
Problem Description
When working with Corona materials in the Material Manager:
Adjusting any material parameter (e.g. color, roughness, etc.)
Triggers the material preview (thumbnail) to refresh
During this process, the C4D interface becomes noticeably laggy or temporarily freezes
Key Observation (Important)
A critical detail of this issue is:
The freeze happens without any noticeable increase in CPU usage
Specifically:
Material preview shows as “updating”
C4D UI becomes unresponsive (similar to a freeze)
However, CPU usage in Task Manager remains low or unchanged
Technical Assessment
Based on the behavior, this does not appear to be a performance bottleneck, but rather:
Material preview seems to be running on a blocking UI thread (main thread)
In other words:
Material update triggers preview refresh
The main UI thread becomes blocked or waiting
Resulting in the entire interface freezing
This does not behave like asynchronous background rendering.
Steps to Reproduce
Create or load a scene with multiple Corona materials (10–20 is enough)
Open the Material Manager (with thumbnails visible)
Modify any material parameter
Material previews begin updating
The UI becomes laggy or temporarily frozen
What Has Been Tested / Ruled Out
This issue still occurs under the following conditions:
No textures at all (pure parameter-based materials)
No rendering in progress
Simple scenes
Additionally, I have already tried multiple optimization approaches:
Lowering material preview quality to the minimum (e.g. 0.1)
Reducing available CPU threads for Corona
Using simplified preview scenes
None of these had any noticeable effect on the issue
Therefore, it is likely not related to:
Texture I/O
CPU limitations
Scene complexity
Preview quality settings
Version Testing (Important)
This behavior has been tested across multiple versions of both Cinema 4D and Corona Renderer, and the issue appears consistently.
This suggests it is not version-specific, but rather related to the underlying preview mechanism.
System Info
CPU: AMD Ryzen 9 7950X
RAM: 96 GB
GPU: NVIDIA RTX 4080
The issue occurs even on high-end hardware, further indicating that this is not a performance limitation.
Impact
Significant slowdown when editing materials
Frequent “freeze-like” interruptions
Poor workflow experience in scenes with multiple materials
Suggested Improvements
It would be very helpful if the following could be considered:
Provide an option to:
Disable automatic material preview updates
(to avoid constant refresh triggers)
Improve architecture:
Move material preview updates to a non-blocking / asynchronous process
to prevent UI freezing
Alternative preview mode:
Provide a lightweight OpenGL / GPU-based preview mode, similar to native C4D materials
for faster interaction during look development
Additional Notes
Native C4D materials do not exhibit this issue
The problem appears only with Corona materials
The issue becomes more severe as the number of materials increases
Summary
Currently, Corona material preview in C4D appears to behave as a:
synchronous, blocking process tied to the UI thread
This significantly impacts usability in real-world workflows.
Any improvements in:
preview control
threading model
or lightweight preview options
would greatly enhance the user experience.
Thank you for your work and support!
