C4d Crashes - Corona 2017-12-14
I have a kind of a heavy scene, with a lot of sweep, clones, Mograph, and objects, when i click render, it simply crashes, sometimes says that Corona dll crash, sometimes says that C4d stop working, for simple scenes its working fine.
The render don’t even start, however, the version 2017-12-7 renders normally, even with more objects in the scene.
PS: Not sure if the bugreport says anything but i attached in the topic.
_BugReport.txt (173 KB)
I can confirm this crash!
Rendering interior, no problems, switch on render instance trees and crash every time.
Beta version 14-12-2017
Cheers
Same probleme, crash with instances !
Finally, I successfully reproduced the crash, and I can confirm that it is connected to render instances. I am looking what is the cause of the issue right now.
Nikola
the crash should be fixed in the latest daily build ([https://forum.corona-renderer.com/ Corona for Cinema 4D Beta 1 daily build - Changelog #msg117089](https://forum.corona-renderer.com/ Corona for Cinema 4D Beta 1 daily build - Changelog #msg117089)). Can you please confirm it?
Nikola
Render Instance works perfectly for me with this new update, thanks :smiley:
R18 - Mac
works for me, perfect timing … this morning i work’s with many instance, crash render … and a few hours later the update arrive :wink:
