C4d crashes using Project Asset Inspector
Hi everyone, hope you’re all doing well.
For a few months now, Cinema 4D has been crashing instantly whenever I try to relink textures using the Project Asset Inspector.
I’ve discovered the issue specifically happens when using Corona Bitmaps instead of standard bitmaps.
This is a major bottleneck when dealing with high-volume assets, like converting models from 3dsy.
Has anyone else encountered this, and are there any workarounds or fixes available?
Thanks in advance!
Hi, no issue so far on my side, which version of C4D and Corona are you using ?
last daily corona, and both c4d 2024 and 2016. same crash on both
Are you also getting those crashes in Corona 14 Update 1 Hotfix 1, or only in the newest Preview build? Could you please contact us about this here - https://support.chaos.com/hc/en-us/requests/new
I have been having this too. Multiple versions. It seems to occur especially updating an HDRI to the sky object.
Relinking every thing else first, then doing the sky manually seems to work.
