I am using C4D R25.010 with Corona Renderer 7 (hotfix 2) on MacOS Catalina 10.15.7. Whenever I try to render a scene with corona sun, C4D crashes with a message “The plugin CoronaCore has crashed.
More information can be found in /Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/_bugreports/_BugReport.txt.” I tried to find the bug report but there is no Maxon folder under /library/preferences/ so I cannot attach a bug report file sadly.
which folder did you delete when following the steps in the link attached? Those paths are for windows, and for Mac there are actually two Application Support folders, which can be easily interchanged.
The correct path for the “hard license reset” is Users/~/Library/Application Support/Corona/
(~ stands for your mac user name).
Note that if you have hidden files hidden, you might need to press SHIFT+CMD+. (dot) prior to this.
Afterwards, delete the contents of this folder (you don’t have to delete MaterialLibrary folder)
I am sure that when I linked that solution there were steps for mac users too. (I don’t know what happened, they probably updated it.) I deleted the contents of the folder you mentioned couple of times. After deleting the contents, Corona Plugin wanted me to activate my license again so I guess I deleted the right files?
For those that are still experiencing this issue, running the latest V8 daily build should resolve this issue. If you can please test it out and let us know, that would be great.
