c4d denoising question
Hey!
In the older corona renderer versions the denoiser was simple. I just had to turn on the full denoising on corona settings, and it worked.
But now i turn on the “corona high quality” denoising option, and it doesn’t work. If i stop the interactive render, no denoising process.
I attached a video file.
Please help me find out what i did wrong.
another detection:
There is denoising process if i do the render in the picture viewer window, but there is no difference compare to denoising without.
Corona’s High Quality denoiser works with regular Rendering & not with Interactive.
So, after you pres Stop, just pres Render (Play button) and regular rendering will start with Denosing showing up as active.
eg
NOTE:
NVIDIA’s GPU AI intended and works for fast Interactive previews.
You can find more in detail on…Corona Renderer Helpdesk: How to use denoising?
thank you so much :smiley: i forgot this one
