VRay 5 support partially C4D Filter Shader. When using brightness result is very strange.
So i thought the best way would be to use the VRay 5 Color Correct Shader, but it seems it do not exist.
It’s however a basic and the most used shader in 3d rendering, so maybe i missed something about this?
for DR, I can only use the node material, if I need to make some color correction?
ATM I cant test DR, but have to prepare a scene. C4D Shaders wont work, I guess.
Hi @folklore , apart from the node materials, you can use the filter shader for DR, as well as all the natively supported C4D shaders (listed here). The ones that have “partial” support (such as the filter shader), mean that the shader parameters are translated to native V-Ray representation. This means the shader is supported for DR, Vantage and Cloud rendering. Unfortunately, since the shader itself is native in C4D, we can not override its preview, so slight differences from the preview and the rendered result are expected. In the case of the filter shader, it should generally render very similar to the preview, except the"Lightness" parameter, which does not have an equivalent in V-Ray.
If you need exact result, you can also always force baking of the shader, by using it inside a VRayC4DBake shader. The baked shaders also work in DR, Vantage or Cloud.
So I dont have to put all textures in a “vray bitmap shader” that they render correctly with DR?
Yes, there is no such requirement for V-Ray 5. This was only necessary for V-Ray 3.7.
