using grass kit v4. Grass doesn’t show up using IR render or interactive rendering. Only final render.
This a bug or correct for anyone else?
Hi, what is Grass kit V4?
Grass distribution plugin. No, not drugs related!
It probably uses Multi-Instances then, given the description of the issue.
Ha! You might want to contact the creator? ([https://forum.corona-renderer.com/ UPDATED GRASS KIT V4.5 | CINEMA 4D R20+ ](https://forum.corona-renderer.com/ UPDATED GRASS KIT V4.5 | CINEMA 4D R20+ )) We don’t have this plugin so testing would be an issue. I would also suspect it uses multi-instances.
