Yes some features are missing, for the color corrections you can use the filter shader (or the color correction node in the node editor). For the transformation you can use the UVW randomizer.
The Layer Shader is extremely powerful,
you can do a lot of things in one place without having to nest shaders
you can switch layers on/off, leave options or variants inside.
and all of that in a nice and very compact gui !
We will see if the support for the C4D layer shader can be improved, however, currently, we only support it partially due to compatibility reasons. Adding full support for the Layer shader might lead to issues when rendering with Chaos Cloud, Vantage, V-Ray GPU, DR, etc. as the effects, listed above can’t be translated to V-Ray plugins.
