C4D Light with texture projection visible in IR
Hey, as far I know the only way to make “projection mapping” light is by using C4D spotlight with material with transparency texture.
This solution unfortunately doesn’t work in Interactive Rendering is it possible to request for that feature?
And also to keep in same topic. Would be really good to have proper corona light where you can apply alpha/color texture and use it as projector on walls/fog. edit: I found another topic abut it.
Thanks.
Visual example attached
+1
