Hi, when will Corona render 7 or above be available for C4D R25?
we are actively working on delivering a v8 daily build that would support R25 as soon as possible.
The V7 Hotfix 2 version will follow soon after.
Thanks,
Jan
Perfect! Thx
The V7 won’t support R25 ? So why bother with V7 hotfix2 ??
V7 hotfix 2 will be a release primarily dedicated to R25 support, with an addition of some crash/bug fixes.
Thanks,
Jan
Thanks for the clarification
Is it v7 we shall wait for or is it v8? I want to try the new C4D 25 version ![]()
"V7 hotfix 2 " - the answer is in the post ![]()
(You can try the daily build of 8 that came out yesterday, if you want to try Corona in R25 now - once that daily confirms there is no problem, we will be putting that R25 compatibility into Corona 7 and releasing that as hotfix 2)
If you want to try out R25 with corona, feel free to use the V8 daily build https://forum.corona-renderer.com/ Corona Renderer 8 for Cinema 4D daily build - Changelog #msg189974
The more users play around with that, the merrier.
Thanks,
Jan
Don’t forget you can have V7 for S24 and V8 for R25, so there is absolutely no risk in trying.
