C4D render 'options' disappear when switching to corona
On the drop down on the left where you chose your render engine there is the category ‘options’ listed below which includes the option to render active object only which is really handy. However when you select corona as the render engine this disappears. With Vray selected the ‘options’ menu stays and you can use the render only active object option so im hoping its a quick thing to add in the SDK. Thanks
